Counter/Timer
measure pulse width with 4 counter simultaneously
I am using NI PCI-6601 measure the pulse width with 4 counter simultaneously, due to only a DMA channel on this card so I selected interrupt data transfer mode to read data from PCI bus for 4 counters, but it working only for few seconds then a error message prompted:
Error -200141 occurred at DAQmx Read (Counter 1D DBL 1Chan NSamp).vi
Measurements: Data was overwritten before it could be read by the system.......(See attached picture: TestUI and Error MSG.bmp)
I know the problem caused due to system is unable to read back data from PCI6601's memory as fast as they card countered. My quesition is:
1. The timebase is 20Mhz(Sample rate), how to change the sample rate slower (like 100Khz) ?
2. Any good solutions can meet my requrement?
Attached is my source code, Test.vi is the main VI.
Thanks for your help.
Steven
(5,853 Views)
Hi Stephen, you should increase the number of samples per channel in DAQmx Read VI.
(5,845 Views)
What's more, you could include four channels in one task, so you don't need to build four task!
(5,843 Views)
