Hi i am new user and i got pxi 6602 iwant to generate a 5 khz 3.5ms 2.5 amplitude and 2.5 offset i probably need to use 2 counters can someone tell me which wires i need to connect on scb 68 device and how ican write this program? Thanks for helping me
Did you read the specs before buying the device? You can't use any counter, let alone two. The device has TTL compatible signals so no amplitude or offset control. A card with timed analog output would work.
