04-12-2012 04:11 AM
I'm using cDAQ9174 and NI9401; I need to generate two synchronized square waves (using two counters). The two waves could have different frequencies (from 500Hz to 7KHz) and duty cycles, but I need they start at the same time (first rising edge together). Is there a way to synchronize the two tasks? I would prefer without using an external trigger.
Thank you in advance for the answers
04-13-2012 06:24 AM
Hello Domcar,
I think the best way to synchronize your two counter outputs would be to use a dummy task as shown in the following link. Could you please take a look?
https://decibel.ni.com/content/docs/DOC-11755
