Counter/Timer
tab constant ?
under strings what is the diff b/w
Tab const
line feed const
carriage constant
end of line constant
if possible explain with a small example please
(5,462 Views)
Accepted by Nagaa
These are just replacements for writing ASCII codes. For instance, If you want to write some text, and you want to input :
A Tab space ( \t ) : you use TAB constant
New Line ( \n ) : you use LINE FEED constant
Carriage or Enter ( \r ) : you use CARRIAGE constant
End of line ( \r\n ) : you use END OF LINE constant
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(5,458 Views)
Thank u sir
Best regards
nagaraja
INDIA
(5,452 Views)
