10-13-2009 04:01 AM
i am the new guy just started my labview learning, i want to connect a encoder with 5 lines to the NI X6221 board, i have read some of the question posted. i have read the manual also, but the munual just mention that there are 2 pins on this board which can be used as a counter. but i just do not know which 2 can bu used? what's pin no. and how to read PCI/PXI-6221 (68-Pin) Pinout diagram. which pin no should i used to connect the encoder from the NI 622x Specifications page 14.
10-13-2009 06:15 PM
Use DAQ Assistant to configure counter channel.
It'll tell you which PFI line connect to which signal.
Then, go to Start>>All Programs>>National Instruments>>NI-DAQ>>NI-DAQmx Help.
Search 6221, and see which pins belong to which PFI line.
