Recently set up our agilent 34970a running 2 cards with our measuring program which is run by dasylab. Thought the whole setup was working until we noticed a difference in temperatures on a Thermocouple (confirmed this with a external device) In the initial Agilent Benchlink DAtalogger 3 software, all the channels are configured correctly for the TC type K on the channels and DC volts on the other channels. The agilent is showing the correct config settings on the display, but it seems that when the dasylab program runs, everything works, but it is changing the types of channels to different ones. For example channel 101 is configured for Type K, but when dasylab activates it seems to convert it to the default settings as Type J, and does this for all channels.
This is how we are calling the request from dasylab to the agilent for the channels. Is this what is causing the reset?
If we want dasylab to use the config on the agilent, what should the request and format be? If we want to scrap the config completely, do I need to ask for more in this line to specify what we are looking to get?
