DASYLab
Delay, combi trigger How to delay activation
I am working on a model of digestive tract (7 bioreactors) and willing to activate pumps with different delay to simulate time of digestion
but I dont seem to be able to do it even though i tried differen approach,
So I want every pumps to run cycles of 10 minutes activation every height hours
Pump 0 starting at t=0
Pump1 starting at t=190
Pump2 starting at t= 380
Pump3 starting at t=630 ....
So using  TTL generator is efficient to define cycles
Low TTL to switch On pump
High TTL to switch Off pump
but what about  when t < delay :
It seems thta i can't wrap my mind around functionnality of combi trigger, relay, time delay modules
What I do right now is reading a file with the correct inputs
working on Dasylab 12 and powerDNA cube w/ DNA-DIO-403 & DNA-AI-201
Any help would be appreciated
 Canguilhem
(4,319 Views)
Could you please post your code ? It would help a lot to understand what you are trying to achieve.
Thank you in advance
Maxime L
Certified LabVIEW Architect
(4,287 Views)
Hi Maxime!
After having tried like all kind of approach i finally found an example of syntax for logical tests which allowed me to run my experiment properly
if anyone is interested, here's my solution :
Timebase ->Formula interpreter ->output
like i said i got 4 pumps which starts at different times but almost all the same pace
i.e :
- P0 starts at t=0 is active for 10 mins every 8 hours
-P1 starts at t=190 is active for 10 mins every 8 hours
-P2 starts at t=380 is active for 10 mins every 8 hours
-P3 starts at t=630 is active for 10 mins every 7 hours
Test for P0 : ((IN(0) < ${TIME_ACTIVATION}) OR  (IN(0)  MOD ${PERIOD_P0_1_2} < ${TIME_ACTIVATION})) * 5
${TIME_ACTIVATION}
Test for P1 :  (( (IN(0) =  ${DELAY_1}) AND (IN(0) <= ( ${DELAY_1} + ${TIME_ACTIVATION}) ) ) OR ( (IN(0) - ${DELAY_1}) MOD  ${PERIOD_P0_1_2} <=${TIME_ACTIVATION}) AND (IN(0) > ${DELAY_1}) )*5
I'm not sure i'm clear, what do you think of this solution ? Smiley Happy
(4,280 Views)
