DASYLab
Worksheets stops just after being started
I've just installed DASYLab and started a new worksheet with a Read Simatic module and a Chart recorder. Connections to the PLC are set as well. When I click the start button it seems to start as normal, but after a couple of seconds it stops. No error message. Anyone got a clue what the reason might be? Are there any logs I can retrieve somewhere?
(3,856 Views)
I understand that this has been resolved by phone.
When the issue is related to a driver module, such as the Read Simatic module, it's best to contact your reseller.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,823 Views)
Accepted by aregabriel
The problem was that I had numbered the PLC "160" in the ACCON-AGLink config. Dasylab does not seem to accept a higher number than 126. See attached picture.
Solved now and the 'bug' has been reported to the developers.
(3,821 Views)
