DATA AHEAD toolkit support Discussions
XLR8 - Reading below "last row"
one more difference to plain ActiveX access to Excel:
When reading below the last row of an Excel sheet XLR8 ReadAny gives an error 1172 whereas using ActiveX Range.Value2 method gives just empty cells.
So with XLR8 I have to get the last row and set the correct range before attempting to read the range with XLR8.
Is there a way to handle such problems (attempting to read empty cells) in XLR8 internally?
Background:
I use ActiveX to read in configuration files created in Excel. Those configuration files have a variable number of rows, so I just read a sufficient high number of rows as I have to filter the read table anyway. No problem so far with ActiveX. When trying to migrate to XLR8 I now have to worry about the number of rows in my Excel sheets…
(6,272 Views)
Hi GerdW,
when using the "Read Area" VIs you should be able to read any cells in a workbook, even below last row. Can you reproduce the issue in a simple VI so that we can trace it?
CLD | Alliance Partner | Web data storage and visualization | daq.io
(5,150 Views)
Hi Peter,
attached a small routine for loading the attached XLS file. I try to read range A3:T263 from sheet "Inputs".
With "lastrow?"=FALSE it gives an error 1172, with lastrow=TRUE it reads the data…
The VI looks like this:
(In FALSE case the row constant is wired through the case.)
More interesting: when I read the range starting from A1 both cases work fine. So it's a combination of NOT starting to read in the most upper left cell AND exceeding the last row of the sheet…
(5,150 Views)
Hi GerdW,
thanks for your detailed bug description! We were able to determine the bug, indeed this is a bug in the old format ".xls".
We will provide the bugfix in the upcomming version of XLR8!
Hajo
(5,150 Views)
Hi Hajo,
in previous update posts I found some numbers (like #789). I guess those are your bug/issue tracking numbers.
Do you also have a number for this special bug?
(5,150 Views)
Hi GerdW,
you are right ;-)! The Ticket number for this bug is #802.
Greetings,
Hajo
(5,150 Views)
