DIAdem
Change a global variable when DAC running!
Hello!
I want to change a global variable when I push a button when "Start Display" it's running. I don't want to run script after or before measurement.
Can anybody help me?
(2,139 Views)
Accepted by topic author admyn1991
There are some global variabes that you can use like R1 to to R32. In DAC there is a block "Save in Variables" in the "System" group:
http://zone.ni.com/reference/en-XX/help/370858N-01/dlgdacsv/dac_dlg_system/dlgvari_dialog/
You can use this block to save values in variables. See attach block diagramm.
Or you can use the "script driver". (Can run a script from a DAC?)
Hope this helps
Winfried
(2,114 Views)
