DIAdem
Compress Images on Report
Hello
I am currently generating a report which requires a tonne of photos.
The photo file sizes vary between 4 and 10 MB per photo.
When I generate a .PDF of my DIadem report the file size is quite large.  Is there anyway to compress the image similar to  "Compress Pictures" function in excel?
Tim
Message 1 of 18
(5,979 Views)
Accepted by smoothdurban
Hi Tim,
You can affect JPEG compression and PDF resolution with program variables by setting them in a DIAdem Script. The program variables you would want to set are discussed in these help documents:
http://zone.ni.com/reference/en-XX/help/370858M-01/varoff/pdfjpgcompressed/
http://zone.ni.com/reference/en-XX/help/370858M-01/varoff/pdfresolution/
Hope this helps,
Kevin F
Applications Engineer
Message 2 of 18
(5,953 Views)
This helps immensely
I was able to take a report of 85 MB and compress it to 1.75!
All I had to do was add the following code to my report script
PDFJPGCompressed = "high"
Tim
Message 3 of 18
(5,946 Views)
Awesome, I'm glad that worked so well for you!
Kevin F
Message 4 of 18
(5,918 Views)
Hello
I have tried using this with PDFResolution but it does not have the same desired effect.
Is there a partcular place I shoud be setting my PDFResolution before I call PicPdfExport?
Current I set:
       PDFResolution = "72 DPI"
      Call PicPdfExport(PDFFilename, false)
Will this have the disered effect?
Tim
Message 5 of 18
(5,834 Views)
Hi Smooth,
Your two lines of code look fine to me.  The PdfResolution variable is a global variable that just needs to be set prior to call the PicPdfExport() command.
Brad Turpin
DIAdem Product Support Engineer
Message 6 of 18
(5,823 Views)
Thanks Brad.
The file  PDF file size is quite large and exceeds my 17 MB limit on allowable report size.
Any other ideas on how to compress the .pdf report file?
Tim
Message 7 of 18
(5,797 Views)
Hi Tim,
There are a total of 4 variables you can use to potentially minimize the size of the resulting PDF, depending on what you have on your REPORT layout sheets.  Please give the other two a try and see if that helps:
PDFFontsEmbedded
PDFJPGCompressed
PDFOptimization
PDFResolution
Brad Turpin
Message 8 of 18
(5,787 Views)
Hey Brad
I have changed all of the variable to the following and I do not see any change in file size.  I have a 5 page report at ~ 4MB!
PDFFontsEmbedded = true
PDFOptimization = true
Is this normal for a five page report?  I would of though its size on disk would be significantly smaller.
Tim
Message 9 of 18
(5,782 Views)
Hi Tim,
No that's not normal.  Do you have 3D graphs on any of those pages?  They tend to take up a lot of memory.  Can you send over a data set and TDR for us to investigate?
Brad Turpin
Message 10 of 18
(5,774 Views)
