DIAdem
How to change report font color with script based on criteria
Is there a way to have the font color change for the report based on the determination found in the script?
For example this script checks to see if a value was exceeded and reports yes or no on an alert page of the report.
If Data.Root.ChannelGroups(1).Channels("Speed (rpm)").Maximum > 6300.1 Then
T1 = "YES"
Else
T1 = "No"
End If
I would like the YES text to be green and the No text to be red. Is this possible?
Thanks!!!
(2,380 Views)
Accepted by KarenD
Hi Karen,
You can place the text box you need, select it and right-click on it to rename it. In my example I name it MyText. Then you can use something like this to programatically change the color.
Call Report.ActiveSheet.Objects("MyText").Font.Color.SetPredefinedColor(ePredefinedColorRed)
Call Report.Refresh
You have another example here with a comment box : http://zone.ni.com/reference/en-XX/help/370858M-01/reportapi/properties/report_property_color_irepfo...
CLAMaxime -- Kudos are a great way to say thank you
(2,343 Views)
