DIAdem
Sync Waveform (audio file) and Numeric channels
I would like to listen to a .WAV file in diadem, this is possible.
But I would like to sync. the timeline of this wave signal to other numeric channels.
The numeric channels are used to check for certain events.
If a certain event happened I need to listen to the noise at that moment.
Does anyone tried a similar thing in the past?
Or has an idea to tackle?
Or a script somewhere? 🙂
Thanks in advance
(120 Views)
As always - example data would be helpful.
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(89 Views)
Have a look at the
Synchronizing Maps, Videos, and Measurement Data
which does more or less what you want. Be aware that the cursor must be active in the wave display to play sound when starting.
Hope this helps.
(73 Views)
