08-17-2018 02:32 AM - edited 08-17-2018 02:35 AM
Hello everyone,
when I use the recording mode for generating a script in DIAdem something happens, that I cannot explain:
I choose „digital filter“ (IIR-Filter) and than „high-pass“ with a cut-off frequency of e.g. 6 Hz.
The source code line, DIAdem generates me is:
Call ChnFiltCalc("","[1]/Fx","/FilteredSignal","IIR","Bessel","High pass",2,6,40,60,1.2,25,"Hamming",0,0)
My question is, why are the numbers 40 and 60 appearing? I can change them by changing the numbers in bandpass and band-stop, but all I wanted was filtering with a high-pass and no band-filter. Or do these numbers have no influence on the high-pass and DIAdem still had to write something in the gaps?
Or do I have to change the numbers manually to 0?
Like:
Call ChnFiltCalc("","[1]/Fx","/FilteredSignal","IIR","Bessel","High pass",2,6,0,0,1.2,25,"Hamming",0,0)
Maybe in the case of a high pass, both source code lines mean the same?
Thank you for your help 😃
Greetings
Lukas
08-17-2018 03:15 AM
Hello Lukas,
The function ChnFiltCalc is able to do all kinds of filter calculations including high-pass, low-pass and band-bass. The list of parameters is always the same and there are always parameters that are ignored because they are not needed for this specific type of calculation. If you change the script to a band-pass, the cut-off frequency of 6 is ignored and the 40 to 60 is used.
Greetings
Ulrich
08-17-2018 03:18 AM
Hello again,
I think I have the solution.
The numbers are there for all filters. However, only the required numbers are used for the corresponding filters. This means that the 40 and the 60 have no meaning in the case of the high pass, both source code lines say the same thing.
In return, the 6 has no meaning for a bandpass.
greetings
08-17-2018 03:20 AM
Hello Ulrich,
you were faster. 😉
Thank you very much
