DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
CyGa
Add DQMH scripter access into the LV New... dialog
In order to reduce the number of clicks to launch a DQMH scripter, that would be great to be able to launch them from the LabVIEW New... menu !
Indeed this window has several advantages :
  1. The tree view keeps its layout from one excution to another. So if the last thing I did from that window was to launch the 'New Event...' scripter, next time I'll launch this window this item will be directly accessible
  2. It allows inserting the created code into the project or not. So to create quick code without adding it to the currently open project, this is quite usefull
  3. The tree view makes easier to choose the scripter to launch. With Tools menu, if the mouse pointer accidently leaves the menu and overs another menu entry, you've got to go back and re-do some of the menu selection process
  4. A LV keyboard shortcut can be added to the New... action. In my case I redirected the CTRL+N shortcut to launch the 'New...' window instead of triggering the 'New VI' action. It would allow me to launch a scripter with 1 keyboard shortcut + 1 double click ! Quite fast !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
3 Comments
Olivier-JOURDAN
Status changed to: Declined
Not a priority.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Status changed to: Development Started
Olivier Jourdan
CyGa
Actually done by Neosoft and published on VIPM : https://www.vipm.io/package/neosoft_technologies_inc_lib_dqmh_new_menu/
