By default, in the MHL Error case, the "error out" local variable is written to. But the error that is written is NOT the error that came into the MHL Error case!
I propose the above be changed to this:
By doing this, the actual error that was raised by the module will be copied to "error out"
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
