DQMH Consortium Toolkits Feature Requests
Ozfarmboy
Change the Error local variable to show error received
Status: Released
By default, in the MHL Error case, the "error out" local variable is written to.  But the error that is written is NOT the error that came into the MHL Error case!
I propose the above be changed to this:
By doing this, the actual error that was raised by the module will be copied to "error out"
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
2 Comments
Darren
Proven Zealot
I agree with this suggestion as a change to the module templates, but I don't think there should be a validate+fixer for it, as that could change existing application behavior.
mbaudot
Status changed to: Released
Matthias Baudot | Software Architect | Founder at STUDIO BODs | DQMH® Consortium Board Member
STUDIO BODs     BLT for LabVIEW     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
