DQMH Consortium Toolkits Feature Requests
CyGa
Enhance DevX when an event is removed
Status: Development Started
The DQMH target is not known so far.
Today when an event is removed, no special actions are done in the testers and a 'manual search' has to be done in the module's main VI.
Here is what is suggested in DQMH help :
  • In the case of a Request:
    • In the Tester VI:
      • Open the block diagram and find the event frame configured to test calling this request.
    • In the DQMH Module Main.vi:
      • Open the block diagram and find the event frame configured for this request (It might no longer be listed and instead say something like “Unknown Event (0x0)”).
  • In the case of a Broadcast:
    • In the Tester VI:
      • Open the block diagram and find the event frame configured for this broadcast. (It might no longer be listed and instead say something like “Unknown Event (0x0)”.)
    • In the Module Main VI:
      • Open the block diagram and find the places where the broadcast VI is called and remove it.
It would be nice to attract dev eyes on the places where modifications need to be done post event-removing.
Maybe adding a comment like this would be enough ?
It is not much, but the comment color and hashtag would ease the 'finding' process.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
2 Comments
joerg.hampel
Status changed to: Released
We've accepted this feature, but it's ranked as low priority and, depending on the final list of features, might not make it into DQMH 7.0.
DQMH® (Developer Experience that makes you smile )
Olivier-JOURDAN
Status changed to: Development Started
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
