DQMH Consortium Toolkits Feature Requests
ChrisFarmerWIS
Message Name in Error Handler for Message Handling Loop
Status: Released
This was originally raised by Joerg here:
https://forums.ni.com/t5/Delacor-Toolkits-Documents/DQMH-Feature-Requests/tac-p/3974021/highlight/tr...
To quote Joerg:
"Sometimes, the error cluster that feeds into the Delacor QMH Error Handler - Message Handling Loop.vi doesn't convey enough information to identify the origin of the error. For example, an Error "91 - Variant To Data in xyz.lvlib:Main.vi" does not tell me in which MHL case the variant to data operation failed. It would be nice to have the selector label of the MHL's case that the error occurred in."
Feature Request: Somehow (not sure what the best way would be) make the error handler include the last message's name (string) in the error broadcast."
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
4 Comments
FabiolaDelaCueva
Status changed to: Released
This feature is already in development and will be available in the release after DQMH 5.0.
This was one of the ideas selected by the DQMH Trusted Advisors to be included in the next release.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
ChrisFarmerWIS
Excellent! 🙂
Christopher Farmer
Olivier-JOURDAN
Status changed to: Looking for Maintainer(s)
Done in DQMH 6.0
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Olivier Jourdan
