I could program a whole panel to allow the user to modify the setup parameters for a DAQmx task, but decided that it's easer to simply stop the task and launch MAX with LaunchExecutableEx and let the user play with the task settings there. Unfortunately there seems to be no way to tell MAX, e.g. through command line parameters, to open up and display a particular DAQmx task upon startup. Might I suggest some facility for doing this, possibly through simple command-line parameters or even through an ActiveX utility?
