When it comes to documentation of an measurement, you need to report ALL settings of a device that effects that measurement.
From a core memory dump written as a hex string to a XML document.... anything that shows up a difference in the settings that affect the measurement would be fine for documentation.
Something like a big property node readout followed by a format into string .... but make sure not to miss a property.... and a bit more complicated when it comes to signal routing....
A measurement that isn't sufficiently documented is all for naught.
or
Just think of a nasty auditor 😉
It's so easy to make measurements with LabVIEW, please make it easy and consistent to document it.
Example:
A quick measurement setup with the DAQ-assistant/Express fills Gigabytes but after a certain time they are useless because nobody knows how they where taken. A simple checkbox could add all this information in the variant of the waveform. (or TDMS or ...) even if the operator don't have a clue of all the settings that affect his measurements.
