Data Acquisition Idea Exchange
SteveP
Internal Channel for the 5 volt power output terminal so its actual value can be measured
Status: New
If the 5 volt output power terminal were available as an Internal Channel in DAQmx, then its actual value could be measured.  That would allow accurate use of it as the power source for example for external bridge or voltage divider measurements which rely on knowledge of that voltage.  On the X Series USB-6343 for example, that terminal is on pin 96.
1 Comment
SteveP
The Internal Calibration Reference Voltage can be measured as   _calref_vs_aignd
I wish to measure the 5 volt power output voltage.
