Data Acquisition Idea Exchange
JB
New option for number of samples per channel
Status: New
Screenshot from the help for number of samples per channel for a Read task :
Please add an option for a continuous sample task to read all currently available samples (-1) but with a wait for a minimum number of samples (#min). Behavior of this configuration :
  • #available samples >= #min : read all available samples
  • #available samples < #min : wait until #min samples are available or until timeout
This would be very useful in several cases. For example :
  • No extra coding to handle or avoid the error that appears if 0 sample is available.
  • Avoid the use of a wait function in the loop to ensure a minimum number of samples are available.
4 Comments
Seth_B.
Functionality pretty similar to what you are describing is can be implemented pretty easily using the NI-DAQmx Read property "Available Samples per Channel"
Aside from the small increase in code, is there a reason this option won't work in your application?
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
JB
Trusted Enthusiast
Trusted Enthusiast
Thank you for your snippet !
Indeed this will work and I will use it. But some comments :
  •  this solution uses (much) more space on the diagram (as you mentionned)
  •  it needs additional code to implement a possible timeout
  •  in most cases, it is necessary to put a delay in the False case to avoid a too high CPU usage
  •  it is not obvious for beginners
Therefore I think it would be useful to implement all these functions in the DAQmx Read VI.
Kevin_Price
Proven Zealot
Here's the workaround I'd probably use.  You don't have to use CPU polling for # available samples,
and you end up with all available data when buffer holds > min #.
-Kevin P
ALERT! LabVIEW's subscription-only policy coming to an end (finally!). Permanent license pricing remains WIP. Tread carefully.
John_P1
Trusted Enthusiast
Depending on the context of the application, you might also consider an event-driven approach:
However... now that I think about it, the event fires every time N samples are acquired into the buffer so it doesn't quite give you the behavior you desire of obtaining a minimum amount of samples if you are doing multiple iterations.
John Passiak
