07-08-2011 03:00 AM
Hi all, i haved installed TPLA and Protection Plus. However, no VIs were displayed on the palette. A check on the folder shows that its already installed. Anyone facing the same problem? How can i resolve this problem?
I'm using windows 7 and LV 2010SP1.
Many thanks!
07-08-2011 03:21 AM
Did you try restarting LabVIEW?
07-08-2011 03:23 AM
Yupz, i even restarted my laptop.
Below's an image of the palette
07-08-2011 10:19 AM
Could you please check the following path? Please let us know if it does not work.
07-08-2011 10:28 AM
I've seen this issue before and it has to do with loading the palettes. Could you please provide a screen capture of your \LabVIEW 2010\menus\Categories\Programming\ folder?
Also, do you have the Report Generation 2010 toolkit installed from the SP1 distribution?
-Bob
07-11-2011 01:04 AM
Here's the screenshot of "programming" folder and the LV components installed.
Many thanks!
07-11-2011 09:40 AM
The NI Desktop Execution Trace Toolkit is not listed as an installed product in MAX, but the NI_DETraceTool_Menu.lvlib in your Menus\Categories\Programming folder is from the Desktop Execution Trace Toolkit and is most likely causing the TPLAT palette to not show up on your palette. Try removing NI_DETraceTool_Menu.lvlib from this directory and refreshing the palettes (by either restarting LabVIEW or running the 'Refresh Palettes' method).
Please let me know if this resolves the issue for you.
-Bob
07-11-2011 09:13 PM
Many thanks the issue is resolved!!!
07-12-2011
09:32 AM
- last edited on
01-19-2024
11:45 AM
by
migration-bot
I'm glad to hear it! You can download a newer version of the Desktop Execution Trace Toolkit to resolve this issue here:
-Bob
04-26-2012 08:46 AM
Hi all,
I'm having the same issus (no TPLA palette in LV2010), one difference with j3r3mi is that in my \LabVIEW 2010\menus\Categories\Programming\ folder, there is no "addonlicensing.mnu" file...
Any idea?
Epictetus
