03-10-2024 11:41 PM
I thought that Vdd, Supply Voltage has issue by restricted under 3.6V.
You mean that it will be okay when I use active drive mode, right?
03-11-2024 07:24 AM
As per your RF Switch datasheet it can handle up to 5.5V signals on the control pins. Any way, you can still play safe by using Active Drive mode and thereby be within 3.6V on 6501.
03-11-2024 08:16 AM
Thank you very much for your help. I saw a way out of long-standing difficulties.
