Digital I/O
Comparing USB-6351 to USB-6215
I have an requirement described in the attached file. And I want build it up with an USB-6215 instead of an USB-6351.
My question is, can I fulfill all the requirements also with an USB-6215 - specially the HW Timed DIO?
Requirements are:
1x analog input (AI)
2x HW-timed analog outputs (AO)
3x HW-timed digital input/outputs (DIOs)
1x counter
1x Programmable Function Interface (PFI) pin to use the counter output as the clock source
(492 Views)
Yes you can use this USB 6215 as its HW timing exceed 10 MHZ up to 100 MHZ
CLA
(484 Views)
Accepted by frettt
By my reading of the spec sheet, NO.
The USB-6215 does not support hardware-timed DIO.  Nor do any of the other USB-621x (M-series) devices, to the best of my knowledge.
If USB is a requirement, you probably need to stick with the USB-63xx (X-series) family of devices.
-Kevin P
(461 Views)
As Kevin indicated, USB-6215 does not support HW timed digital IO
Santhosh
Soliton Technologies
(445 Views)
