08-02-2016 10:22 AM
I was wondering if someone could help me. I'm having trouble generating a logic LOW output with my NI-6528 and LabView Signal Express LE.
When I configure continuous signal, I don't get the option to configure my signal to be HIGH or LOW. Also, I get an erorr regarding missing inputs. Does anyone have any ideas or helpful links? I've attached the screenshot below.
Thanks in advance to anyone who can help!
Jenny
08-02-2016 12:17 PM
Hi everyone,
Just as a quick update, I found that outputing a 1 sample signal did not result in any error messages. My goal is to just output a signal LOW to one of the output ports on the Ni-6528.
The user manual states that our output ports are just solid state relays that close upon receiving a logic low signal.
Using LabView Signal Express LE, I’m trying to generate that logic low signal to port 5 line 7. I believe I am successful, but when I use a multimeter to verify, I find that the connection between pins P5.7+ and P5.7- is open (not closed as expected). Am I using LabView incorrectly (please see attached image)?
08-03-2016 07:18 PM
Hi Jenny,
Are you able to use any of the other pins? and do you see the same behavior?
Are you using the PXI or PCI form factor?
