Digital I/O
How to config P0.0 read enable and P0.1 write enable by using PXIe-7975R&NI 6581B
I found that I can only set P0.0 to P0.7 in the same mode (read or write) in PXIe-7975R & NI 6581B , but how can I set P0.0 write while P0.1 is read mode.😫
Hope your help sincerely , thanks.
(1,491 Views)
Accepted by JoronoJobana
According to the specification, the direction control is on a per port basis.  So, unfortunately, you cannot have P0.0 be an output and P0.1 an input at the same time.
GCentral
(1,451 Views)
Thanks a lot.
(1,395 Views)
