Digital I/O
Making a counter using a switch
Hello
I am programming a robot for school.
My problem that i have run into is that i want to make a counter using a given switch.
Basically the principle is that the switch is attached in such a way that when a gear rotates, the swich is either pushed in or not pushed in.
I would need a piece of program that counts the rising edge of the voltage each time(i think) but have no idea how to do this...
anyone out there that can help?
(3,184 Views)
Hello Tim,
Which kind of hardware and software are you currently using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,166 Views)
