01-21-2021 02:36 AM
For a project with an encoder I want to use the NI-9411.
My question about this module is what is the maximum sample frequency?
What is the maximum frequency that the module can measure?
The manual tells me only the input delay time of 500ns.
Kind regards,
Stephan
01-21-2021 09:31 PM
Regarding to your question on the maximum frequency for NI 9411, you can find in the link below.
Solved: Measuring high frequency with NI 9411 - NI Community
Since you mentioned about using NI 9411 with an encoder, you can also view this link for your reference.
Wiring an Encoder to the NI 9411 Module - National Instruments
You can refer to the "Help-->Find Examples..." in LabView for example usage of NI 9411 in the link below.
Solved: Frequency measurements using cDAQ-9178 and NI 9411 module - NI Community
Best Regards.
