Digital I/O
Multiple loops
Hello. I am trying to create a nested loop structure for the front panel of vi for HP 4140B pico ammeter. The algorithm is as follows
Initialize Va limit
              time step
              select wavefrom type
              time delay
Start
0 to Va
Next
Va to 0
Next
0 to -Va
Next
-Va to 0
collate data
print graph and save to a text file.
Now the instrument does not have multiple sweeps either it is ramp up or ram down , staircase up or staircase down or D.C. So either through loops I can do it or trigger the D.C at various levels with conditions and counters and colate the data.
Any advise on how to implemet it. I am using the library which I downloaded from the ni.com. Links to multiple loops examples will be very helpful.
Regards
Karan
(3,131 Views)
Hi Karan,
Is the VI you posted what you have done so far? You should consider using a state machine structure for each ramp up and ramp down.
State Machine:
http://zone.ni.com/devzone/cda/tut/p/id/7604
Hope this helps!
Chris T.
(3,103 Views)
