Digital I/O
NI USB 6525 Error -201278
Hi all,
Im running into some trouble with the switching rate for the usb 6525. I know the specs list it at 5 operations per second. Can anyone verify if this means 5 full cycles between on and off?Or does an operation simply mean a transition from 0 to 1 or vice versa? I was told that the usb 6525 can handle a switch rate of 5 Hz but I am only able to achieve up to 2.5 Hz before I get the error of "Consecutive writes to a digital line occurred more frequently than the device can safely allow." If anyone could clarify this for me, that would be awesome.
Tyler
Message 11 of 11
(1,034 Views)
