04-02-2021 10:35 AM
I have a DUT with a ground that is floating 3.3V above earth ground. Vss of the DUT is set to -3.3V (relative to DUT gnd) which makes Vss equivalent to earth ground. Can I hook the 6570 ground pins to DUT Vss without harming the 6570 functionality? The idea is to allow me to use the 6570 with positive logic voltage levels, relative to earth ground, but the DUT would see negative voltage levels relative to DUT ground. My requirements are VIL < -3V and VIH > -1V.
04-02-2021 12:56 PM
That sounds like a good idea.
Caution!
Though all these are theoretically possible, I would definitely recommend you to set up a proof of concept board with DUT with adequate current limiting resistors and verify the actual behaviour as expected.
