Digital I/O
PXI 6733 Discrete signal CTR 0 OUT Pin Default is High
Hello
I have PXI 6733 PXI Analog module mounted in chassis, But CTR 0 OUT Pin is HIGH (5 V) all time by default. Instead Low any advise how to make it low?
(1,060 Views)
As per the manual, it is in high impedance state at startup, try connecting a 10k pulldown resistor to check if it is actually driving HIGH.
Anyway, I found this property node to configure the default state, maybe this helps,
Santhosh
Soliton Technologies
(1,027 Views)
