Digital I/O
Static and pulse I/O with NI-9401
Hello.
I'm working on my first project and I need to use a cDAQ-9189 with one (or more) NI module that allows to have:
8 digital output (1 must be used to generate a pulse train and the other ones must be static)
16 digital input (1 must be used to measure frequency of a pulse train and the other ones must be static)
I prefer 0 to 5V signal level, but I could use also something different.
What could be the best choice?
I have seen the NI-9401 but has less channels, and the NI-9403 but it seems that can't mange pulse train generation or measuration.
Or maybe the NI-9375?
Thank you
Best regards
Message 1 of 9
(844 Views)
cDAQ Module Support for Accessing On-board Counters provides a list of modules that support pulse train generation and measurement.
You can choose one depending on your budget, voltage range, channel count and rate.
Message 2 of 9
(819 Views)
I choose to use the NI-9401 and configure 4 ouputs and 4 inputs. Is it possible to have 3 static inputs and 1 input for measuring the frequency of a square wave (so the input is associated to a counter of the cDAQ)? Thank you
Message 3 of 9
(787 Views)
And also for the outputs, is it possible to have 3 static outputs and 1 output for pulse train generation? Thanks
Message 4 of 9
(778 Views)
Just tested using simulated cDAQ and NI-9401. You can use 3 DI + 1 CI + 3 DO + 1 CO in a single NI-9401.
Make sure you are setting the input and output in the set of 4 channels. Reference: Configuring the NI 9401 for Simultaneous Input/Output
Message 5 of 9
(764 Views)
For example, I want to have an output to generate pulse train. I have seen that when I go inside NI MAX in Test Panels>>Counter I/O and select "Mode" = Pulse Train Generation, the number of PFI in "Pulse Terminal" can not be modified and depends on the counter selected in "Channel Name". It works in this way? I ask because instead inside my Labview project I can select any PFI with any counter (I include an image to explain). I still haven't the cDAQ with NI modules so I can't try what really happens.
And before of doing this, I read that I have to configure the nibble of pins used as inputs and the other nibble for outputs, but I can't find how to do it.
Message 6 of 9
(730 Views)
NI MAX provides limited support. Use DAQmx API to access the full flexibility.
It is provided in the Configuring the NI 9401 for Simultaneous Input/Output I mentioned previously. Did you open and read the KB?
Message 7 of 9
(709 Views)
I did not explain myself very well maybe on this: "the number of PFI in "Pulse Terminal" can not be modified and depends on the counter selected in "Channel Name".
I meant that when I select a specific counter, in "Pulse Terminal" is selected a specific PFI that can't be modified, but now I suppose I can do it inside Labview through some instruction.
Message 8 of 9
(700 Views)
Yes, you cannot modify it in NI MAX.
And yes, you can specify a different PFI terminal using CO.Pulse.Term property node.
Message 9 of 9
(684 Views)
