Digital I/O
Windows Service problem with USB-6501 (VB.NET 2008)
I'm using a USB-6501 module and it works fine when I use it in a Windows Desktop Application. When I modify it to run in a Windows Console, it also runs fine.
But when I put the same code of the console application in a Windows Service, the communication won't work. I'm not receiving any exceptions (errors) either.
Is there already something known about this issue?
I'm programming in VB.NET 2008 on a Windows XP Pro platform.
(3,848 Views)
Hi
I found the following related to NT services, it's quite old and might differ a bit from the current way a windows service work but I suspect this might be related to your problem:
This transformation is actually a two-step process, the first of which is the actual conversion of your program, which should be in the form of an executable at this point, into an NT service. This is usually done through the use of another program (SRVNY.EXE) that is a part of the NT resources kit.
The second, more difficult step involves ensuring that your newly-created NT service will load after the NI-DAQ kernel service is loaded. This can be accomplished by making sure that the libraries from the DLL are loaded after the NI-DAQ kernel is loaded.
The most common error encountered in this process is a "cannot open DLL" error. Two things that you may consider in an attempt to avoid encountering this error:
1. Load NDAQ32.DLL dynamically. By using a load library function following a delay, you will give some time for the NI-DAQ service to load.
2. Modify your service key in the Windows NT registry and make it dependent upon the NIDAQ32k service. By doing this, you will force it to wait long enough for the NI-DAQ kernel to be loaded.
In your registry, edit the following key: HKEY_LOCAL_MACHINE » SYSTEM » CurrentControlSet » Services. The NT service that you just created should be listed here, along with Nidaq32k service. In order to make your service dependent upon Nidaq32k, add this line to your service key: "DependOnService: REG_MULTI_SZ: Nidaq32k". This should make your service wait for NI-DAQ.
Best Regards
Michiel
Applications Engineer
NI Belgium
http://www.ni.com/ask
(3,833 Views)
First of all, thanks for the quick reply.
I will try this next week (out of office) and let you know the results.
regards
Dudeke
(3,831 Views)
I tried do load the dll dynamically and did some modifications.
Now it is working just fine. Smiley Very Happy
Thanks for the reply.
Greetz
Dudeke
(3,805 Views)
