03-08-2023 09:48 AM
03-08-2023 11:11 AM
Hi Aiafirst, Thanks for posting on the forums. I'm Matthew with NI.
When you re-image the SD card, it will be a completely fresh image (with no team number set).
Which imaging software are you using (Raspberry Pi or BalenaEtcher)? (https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html)
With a freshly imaged SD card, and the roboRIO connected via USB, are you able to ping 172.22.11.2 and get a response?
03-08-2023 01:20 PM
To image the SD we used BalenaEtcher.
Trying to ping it with a re-imaged the SD card and the roboRIO connected via USB the response is
Pinging 172.22.11.2 with 32 bytes of data:.
Reply from TTL expired in transit.
Request timed out.
Ping statistics for 172.22.11.2:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
03-08-2023 01:25 PM
Ok, so no ping indicates so your computer is failing to establish communications with the roboRIO (for any any of a number of reasons).
Just to be absolutely certain that the device is not functioning, can you try imaging an SD card with the Raspbery Pi imager and see if the device will connect with that SD card inserted?
03-09-2023 07:21 AM
Reimaged with the Raspbery Pi imager and still nothing showing up
03-09-2023 07:57 AM
I've sent an email to the address listed on your profile on next steps.
03-16-2023 11:10 AM
Hello, it sounds like our team is having the same exact problem and we can't find the answer. Is there anyway you can relay the solution if you guys found it? You can reply here or send it to our email topsailroboticsteam@gmail.com. Thank you!
03-17-2023 12:02 PM
@Topsail_Robotics_Team , please post a new thread for your issue. "me too" posts cause confusion for which teams have tried what specific steps.
Also: if your trying to connect via ethernet, (if you're not) try connecting to the roboRIO via USB as the networking modes change throughout use and may or may not work directly anymore.
