el 09-22-2019 11:43 AM
Hi all..
I am new to cRIO and FPGA programming.
I am trying to develop a small control system using cRIO. i.e control the output using the analog and digital input signals
So, how can i send a configuration file/ set point of parameters to FPGA before starting the control system?
Shiju
¡Resuelto! Ir a solución.
el 09-27-2019 06:39 PM
Hello Shiju,
Depends on how you want to set those parameters. One option that comes to my mind is opening the FPGA reference in the Real-Time process, and sending the setpoints/configuration values as front panel controls on the FPGA VI from your file.
Other option could be using Network Published Shared Variables, instead of a file, so you can set those form the host computer, too.
I recommend you read through the following resources:
Moving forward, I recommend you post these types of question in the Real-Time Measurement and Control board, since that one is in English and dedicated to the Real-Time controllers and applications.
All the best,
el 10-04-2019 12:16 PM
Thank you sir for your valuable input.
