cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Guardar archivos en una carpeta
¡Resuelto!
Ir a solución
Hi
I´m trying to create one folder inside the folder "Prueba" that I have created in local disk (C). But it gaves me an error with the function create folder.
I attach the program
0 kudos
Mensaje 1 de 3
2.139 Vistas
Solución
Aceptado por labview99
The output of the function "String To Path" has an incorrect format ("C:\Prueba\14/0_01_14_1620:45_").
The characters "/" and ":" are not allowed in the name.
Aditionally the characters \ * ? < > | are also not allowed.
Saludos.
0 kudos
Mensaje 2 de 3
2.026 Vistas
Thank you Antonio
You are right, I have already corrected.
Best regards
0 kudos
Mensaje 3 de 3
1.996 Vistas
