08-03-2017 07:20 PM
Hi all,
I'm using LV2017. When I attempt to pull in the data this happens. Any idea?
08-04-2017 07:43 AM
MarkCG,
I haven't even gotten that far in LabVIEW 2017. I have tried to install DCAF Core 1.2.0.4 from VIPM and when I attempt to open Temperature Controller Example project I get a "Project or Library file is corrupt. Was able to open the example project in LabVIEW 2016.
08-04-2017 08:07 AM
HI MarkCG, they made some changes in the project in 2017 and that is what is causing the issue. This is a new bug and we are working to fix it.
https://github.com/LabVIEW-DCAF/Scan-Engine-Module/issues/39
Best Regards
08-04-2017 10:49 AM
ah ok I can live without it for now. I'll start looking at github for bugs and report them there if new
