09-01-2016 08:24 AM
I have installed the DCAF framework from VIPM but when I try to open the example configuration in the DCAF editor I get an error saying the system diagnostic configuration class not found. I have included a screenshot of the error and a screenshot of the DCAF I have installed from VIPM. Any ideas on how to fix this?
09-01-2016 10:11 AM
The plugins for the example are not listed in the default search paths. In the DCAF Editor, go to Tools>>Edit Plugin Search Paths and add the DCAF Examples directory to the list if it is not already there.
<LabVIEW>\examples\DCAF Examples
If you are using LV 2015, the path should look like this:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\DCAF Examples
If this does not solve the issue, please send a screenshot of the search paths dialog.
