09-19-2019 05:46 AM
Hello everyone,
I'm trying to use the SVX Create Waterfall Cursor VI, but I can not configure it. In terms of the Cursor List the LabVIEW help is not very meaningful.
You find my example VI attached. Can someone please help me?
Thank you
Solved! Go to Solution.
09-19-2019 08:55 AM
The example found at <LabVIEW>\examples\Sound and Vibration\Waterfall Display\Waterfall Display for Power Spectra (Simulated).vi is a better starting point for configuring cursors for the waterfall graph.
I modified your example by using the SVFA Power Spectrum instead of FFT Spectrum (Mag-Phase) and connecting spectrum info, reset waterfall buffer explicitly on first iteration, and wiring frequency to frequency cursor input. It doesn't matter what flavor of spectrum is calculated, but it is important to connect spectrum info from the spectrum VI to all downstream VIs that process the spectrum.
Hope this helps!
09-20-2019 04:26 AM
Thank you Doug
09-20-2019 07:41 AM
It is possible to lable the line?
09-20-2019 09:14 AM
Cursor labels are not currently supported in the waterfall graph XControl.
You could modify the XControl (either to add labels and/or give each cursor a new color), but that doesn't feel like a recipe for success.
You could add an indicator that you move (either programmatically or manually) to associate with a specific cursor. This could be very manageable if you expect to fix the perspective on the display.
How are you looking to use these cursors in your application?
09-23-2019 06:41 AM - edited 09-23-2019 06:44 AM
Trying to lable engine orders in a simple way.
09-30-2019 08:54 AM
I think this would make a great feature for the waterfall.
