Dynamic Signal Acquisition
shifting peak frequency
I am measuring sound signals using a PCB microphone and NI9234 module. For identical conditions, the fft peak shifts by 2 to 10 Hz on both sides when I take multiple identical samples. Could anyone know the source of change please? The background noise is also similar throughout the measurement.
Many thanks for your reply and time
Jaefer
Message 1 of 13
(4,496 Views)
Please provide more information about the signal source, connections, VI used to capture the signal, sampling rate and some sample data for review.
Santhosh
Soliton Technologies
Message 2 of 13
(4,482 Views)
Thank you Santhosh;
Signal source: bubbling water in a tank
Matlab 2018a to acquire data
Sampling frequency 51200 Hz
sampling time 10 seconds
ICP® Electret Array Microphone model 130A23
NI 9234
Data is so big to upload even for one sample.
Message 3 of 13
(4,473 Views)
What phase noise ( jitter/ frequency shifts) do you expect from a bubbling water tank? 😄
Have a nice weekend 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 13
(4,454 Views)
Thank you, Henrik,
I don't expect any frequency shift.
Happy weekend to you too.
Jaefer
Message 5 of 13
(4,445 Views)
Do you only care about low frequencies? If so, lower the sample rate by a factor of 10 or more and share multiple datasets. Give us some hints, what should I expect to see/hear from the spectrum of acoustic data from a bubbling tank?
Doug
NI Sound and Vibration
Message 6 of 13
(4,439 Views)
Thank you, Doug.
I am interested in the peaks. If the parameters that bubble the tank do change during measurement, why does my peak frequency shift slightly? I just want to know the source of change.
My data file is more than 10MB, so I am not able to upload it here.
Jaefer
Message 7 of 13
(4,431 Views)
One way to isolate if the shift in the frequency is in fact from the signal or an artefact of your code, connect the AI to a function generator that generates a clean sinewave, now your FFT should be consistent.
If the data file is larger, you can even do a smaller capture like 1 sec instead of the whole 10 sec. Do you think your issue will not be reproduced when using just a 1 sec capture?
BTW, you've not shared your MATLAB code so that any MATLAB experts could review whether you are doing things the right way.
Santhosh
Message 8 of 13
(4,426 Views)
Try Santhosh's suggestion (input a known signal to your system). You could also try somebody else's code ( https://www.ni.com/en-us/support/downloads/drivers/download.dsa-soft-front-panels.html#).
That's the best I can offer with no data and no code.
Doug
Message 9 of 13
(4,421 Views)
Many thanks, Santhosh:
I will apply your suggestion
I am using very generic code (attached in the file). I am afraid less than 10 seconds of data may not reproduce the scenario.
Here I have attached a file that contains the code, setup, and frequency domain graph.
Kind regards
Jaefer
Message 10 of 13
(4,404 Views)
