FIRST Robotics Competition Discussions
2014 Field Images
Hello I got to look the sample vision code and setting up the camera and so forth.  However one of them came back and said they could not get the other images of the 2014 FRC field to open up of the sample images included in the code. (I believe the ones mentioned in the bottom of page 51 for the 2014 Vision Processing Document provdied byWPILIB or this site http://wpilib.screenstepslive.com/s/3120/m/8731).  Is there a way to download those?  Thank you!
http://firstforge.wpi.edu/sf/frs/do/viewRelease/projects.wpilib/frs.2014_vision_images_supplement  -  this is the link i was referring to.
(3,419 Views)
There are two sets of example images.
The first is included in the Vision Example. If you want to find them on your hard drive, they are in C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\FRC\Vision\2014 Target Detection. These are the ones referred to by the document.
The second set is on firstforge, which shows the hot goal LEDs. I'm not sure where you found that link. The correct links is http://firstforge.wpi.edu/sf/frs/do/viewRelease/projects.wpilib/frs.2014_vision_images.2014_vision_i...
(2,708 Views)
