09-07-2013 08:09 PM
Can you tell me if the 2014 season edition of LabView for FRC will have the option of being downloaded versus installing it by a DVD. I just purchased a new laptop to use for Labview but it does not have a DVD drive. Thank you in advance for your reply.
Solved! Go to Solution.
09-16-2013 08:31 AM
A work around for this is to copy the DVD to a USB drive (thumb or disk). This is what I did last year and what I do with all of my regular versions of LabVIEW each release.
At the Kickoff or the programming session the day before, ask around, I am sure someone has already done this and will let you use their USB drive or if you have a USB drive, will copy the DVD for you. (If you are at the OK Kickoff I will do it for you!)
Ryan
09-17-2013 04:05 AM
Thank you! Good idea! I will give that a try!
