FIRST Robotics Competition Discussions
2015 Drive Station
How can I change which dashboard opens with the drive station? I have a dashboard that I'm trying to open, but it keeps opening the default dashboard. How should I fix/change this?
(3,842 Views)
I don't know if it's the correct way to do it but you can replace the "Dashboard.exe" file in C:\Program Files (x86)\FRC Dashboard directory. You should probably make a copy of the original Dashboard.exe to make sure there you have a default Dashboard.
(3,131 Views)
Accepted by The_Demp
I actually figured it out, there's a .ini file you have to edit the public user's documents that has a path to the dashboard.
(3,131 Views)
