FIRST Robotics Competition Discussions
A question on activation...[URGENT]
How do I go about activating LabVIEW? I am not sure if an e-mail was sent out with the code or how I am supposed to activate it. I tried looking around on this site and all I found is an outdated discussion that stated help was in the Documents section and I was not able to find anything there either. Any assistance is helpful.
(5,306 Views)
You received a serial number from NI along with your LabVIEW discs, which you can use to activate LabVIEW.  I believe LabVIEW will prompt you to activate when you start it up, but if not, you can use the NI License Manager.
(2,868 Views)
Accepted by BestUsername
It is covered in the manual
Getting_Started_with_the_2011_FRC_Control_System_Rev_A.pdf
The "code" or serial number to use in on page 4
Omar
(2,868 Views)
Thank you, I'm not sure where the diskcs are so I'll use that.
(2,868 Views)
