FIRST Robotics Competition Discussions
CRIO Deployment
Is it possible to deploy your code to the Crio, and have it saved on there and not have to deploy it again? Because everytime I start up the robot, I have to redeploy the code which usually takes 2-3 minutes
(5,788 Views)
Accepted by Team 4376
You can deploy a compiled application to the cRIO (meaning the code runs on its own, you don't need to connect to it from LabVIEW and you can't get to the front panels of the VIs).  You will need to do this prior to the competition.  The default robot project should have a build specification for a real-time application.  Right-click the build specification, choose Build.  After it finishes compiling, right-click again and choose Deploy, then Set as Startup.  Your code will start the next time you reboot the cRIO.  If you connect to it within LabVIEW when there is a startup application running, you'll get a warning that connecting to the cRIO will stop the application.  You can just click "Next" when this warning appears.
(3,118 Views)
See Tutorial 4 from the Tutorials Tab in LabVIEW
Scroll down to
Building and Deploying a Stand-Alone Application
It will walk you through the steps you need.
Omar
(3,118 Views)
