02-10-2012 01:07 PM
I am looking for a way to make th robot turn right and left, can i use the arcade drive wpi to do so..
02-10-2012 01:32 PM
Hey rorim,
Yes the arcade drive will set the motors to perform a left turn (left motor reverse, right motor forward) if you move the joystick to the left - assuming you have the motors set up in a standard configuration. Are you not seeing that behavior when you use it?
02-10-2012 03:01 PM
Yep i tested it and it worked.
Thanks!
