01-26-2010 02:50 PM
I cannot deploy any codes from the Classmate to the CRIO. i am able to run the codes from my regular laptop
01-26-2010 04:21 PM
Are you able to see the cRIO-FRC in your project and connect to it on the Classmate?
What is the specific issue you are having that is causing to you not be able to deploy code. By this I mean, what is different than your laptop?
01-28-2010 05:31 PM
Yes i see the CRIO and am able to image it, but when i try to run a program, it stops on the waiting for CRIO and will stay that way until i disconnect and close
01-29-2010 09:57 AM
Are you doing this through your wireless network (Bridge, Router) or with the crossover cable?
01-29-2010 06:06 PM
I am using a crossover cable in case the wireless network was to shut down in the middle of something.
02-01-2010 09:24 AM
If you have any Firewall/Virus Scanner Software, try disabling those and try again. This includes the windows firewall which may be on by default. Also, verify that your computer's IP address and the cRIO's IP address follow the 10.xx.yy.Z pattern. (Where Z is 2 for the cRIO, etc)
02-03-2010 03:23 PM
my classmate has the firewall off and both the CRIO and Classmate have the correct IP address and is still not working.
02-03-2010 04:01 PM
Hi Meerick,
Can you post a screenshot of the Deployment Progress window as it's waiting for the cRIO?
02-04-2010 05:49 PM
Hi Meerick,
If you right click on the cRIO target in your project and select Connect, what happens?
Have you tried power cycling or resetting the cRIO? Are you running the code from the LabVIEW development environment or are you building a startup executable and deploying that?
Are you seeing a dialog box that looks something like this (with your cRIO's name instead of "DisCo-cFP-2220")?
Aaron P
NI FIRST Support
02-05-2010 02:07 PM
I have tried each of the steps and I keep on getting the dialog box, which stays up until I disconnect. this happens anytime i try to connect or deploy to the cRIO from Labview.
